Yes, I agree. TLS Guy would certainly know.
I also know for certain that I've never altered the cables on any turntable. The phrase "If it ain't broke, don't fix it" applies here.
There is a good reason why turntable manufacturers have avoided installing RCA jacks, instead of the hardwired cables 3 to 4 feet in length. They don't want owners to use longer cables.
A typical moving magnet pick-up cartridge generates a low voltage signal, roughly 2.5 to 5 mV. (Moving coil pick-ups generate even lower voltages.) These weak signals are prone to picking up noise (RFI or EMI) or loosing high frequency audio signals via cable capacitance. The longer these cables are, the worse these problems can be.
Only recently RCA jacks have appeared in new turntables, but only in those that have built-in phono stage preamps. These preamps boost those low voltage signals to about 150 mV, similar to the analog audio line level signals from other sound source devices other than turntables. At these voltage levels, the audio signal is much less prone to interference from RFI/EMI or loss via capacitance, at much longer cable lengths.
