Tubes vs. Transistors 1972
psbfan9
psbfan9
First, I'm not trying to start a debate. I thought this article was interesting.
Butler Audio: Tubes vs. Transistors
I have noticed that most discussions are about transistor type amps when someone is looking for a multi channel amp. That led me to search or a multi channel tube amp because I didn't know if they existed.
Here are two multi channel tube amps from Butler Audio.
3 channel
Butler Audio
5 channel
Butler Audio
3db
3db
The only advantage tubes have over transistors is that they are impervious to an EMP pulse such as that from an atomic bomb or from a solar storm.
cpp
cpp
The output of a tube amps are rich with even order harmonics which gives it a 'warm" sound especially at clipping. That's why there's an appeal for the tube sound. I'm not saying its right or wrong but that's just the way it is.
Man that is why I love my tubes in my vintage 67 Fender Vibrolux Reverb :cool:
Solid-State
Although I'm not a tube proponent, I don't agree with the author's assessment of tube sound. The output of a tube amps are rich with even order harmonics which gives it a 'warm" sound espcially at clipping. That's wht there's an apeal for the tube sound. I'm not saying its right or wrong but that's just the way it is.
Sure and you can do the same with with Izotope's Ozone in DSP if so desired.
Yes, maybe so, except tubes are rich in both even and odd harmonics.;)
Perhaps FR and phase shifts adds to the mystique?
3db
3db
Odd harmonics are not a characteristic output of tube amps so I'm surprised you mentioned that. Phase shift? No more than a solid state amp.
3db
3db
I hope you have a point :rolleyes: because I do not see a correlation with the point I made about tube amps sounding differently than SS amps and your troll like response.
Well, what I have read from those who test them, do see just as much odd harmonics.;)
just for one
http://en.wikipedia.org/wiki/Tube_sound
Perhaps you are thinking about the distortions when it clips? But, that is outside of proper operation and is only a special case.
cpp
cpp
jinjuku he's one of mine to. I enjoy the instrumentals in 'Ah Via Musicom'
3db
3db
just for one
Tube sound - Wikipedia, the free encyclopedia
Thanks Mtrycrafts. maybe I'm thinking at the point of clipping. I read the article and I guess the harmonics depends on the class of amplifier topology used. Most of the time, tubes are used in the class where even order are more prevalent and thus incorrectly get labelled (like I have ) as producing only even order harmonics.
jonnythan
jonnythan
Tubes are great on a guitar amp. Really, really great. Not so much for home theater.
Unless you are doing this stuff on a daily base, I am don't, and do it hands on with instruments, hard to keep track of all the stuff about it:D
Also, reading other sources, distortion would also depend on single ended, or push-pull types too.
I'd also would like to see the study that shows even order is more pleasing when audible but not clipping ;):D Rather not rely on urban legends and myths;):D
