For the longest time I have wanted to try a tube amp (even borrow one for a weekend if that was possible) to run my Klipsch Heritage speakers. I have heard that these speakers sound best with a tupe amp. Well I found one that was restored and for a decent price. But my question is this: If I got it and hooked it up to the front pre-outs on my RZ50, would that not defeat the purpose of using a tube amp (if a tube amp is actually better) since I would still have a SS connection in the chain? A couple years back TLS Guy said (in so many words) its not all it's cracked up to be. It is a legendary Dynaco ST70.
I restored an ST70 some years ago. It is bunk that they are superior to solid state amps, at least the amps I use. The problem with tube amps, is that there power is limited and clipping is clipping, whether is so called soft, or not as the enthusiasts call it. I can assure you it is far worse than NO clipping.
The issue that really is a major problem for tube amps, is that they cope poorly with impedance swings. This is a problem as decent passive speakers are baffle step compensated. All my speakers were. The issue is the output transformers, as they give tube amps a high source resistance relative to solid state amps. This makes their response upset by the speakers impedance curves. Baffle step compensation in a passive speaker pretty much always causes an impedance drop.
Much is made by tube enthusiasts of the fact that tube amps are all pretty much class A, and therefore don't have crossover distortion at low signal levels. However tube amps invariable have higher distortion at the higher ends of their output. However good solid state designs are biased class A at low outputs and transition to B. This is for reasons of reducing power consumption in the output devices. In a class A biased amp the power consumption and heating of the devices is constant however loud you play it.
I doubt that the low output level crossover distortion is audible in most designs.
I use unique amps that are called current dumpers by their designer the late Peter Walker. The output stages are heavily biased class B, and there is a very accurate class A amp that generates a feed forward error correction signal. It is a brilliant solution and even when pushing them hard they only get mildly warm and never hot. Since heat kills this contributes to the reliability of these amps. As you have heard they sound excellent.
A couple of words of warning about tube amps. NEVER have the amp on, not connected to the speakers. This destroys the output tubes fast and often makes them explode.
The other warning, is that amp is now old. Do you know if it has been restored? The voltages are high, and the aging high tension capacitors can explode without warning.
This happened to me when I was working on an old tube amp as a kid. The thing exploded violently and I was lucky I was not badly injured. It was a shock I will never forget.
Those ST 70s do have a protective cage, and for this reason.
Anyhow I sold the ST 70 after a year or two at a handsome profit.
