Tube amp advice, any good?
john11
Hi Everyone.
I have never built a tube amp before so have no idea in which direction to go or what to look for so would really love some advice, pointers, general impressions or anything else at all on the following.
Can you please have a look
Douk Audio EL34 Valve Tube Amp HiFi Single-ended Class A Amplifier Board DIY Kit 8589944626153 | eBay
Douk Audio 6J1+FU32 Valve Tube Amplifier Single-Ended Stereo Power Amp Board 6409926346478 | eBay
1pcs Vacuum Tube Power Amplifier Board DIY KIT Audio Amp 131X98MM | eBay
6N2+FU32 Tube HIFI Stereo Power Amplifier Finished board 3.5W*2 | eBay
6P13P Valve Tube Amplifier Board Single-Ended Class A Stereo Amp DIY Kit 7Wx2 8589944623336 | eBay
There is a circuit diagram for one of them and the others have quite a few photos, is anything at all discernable.
I want to use them for mid and treble, i already have an active sub for the bass end.
slipperybidness
slipperybidness
Hi Everyone.
What speakers are you trying to use? If you are gonna use any of these designs, you better have very high efficiency speakers, these look like what the hobby calls "flea amps", b/c they are very low power.
Unfortunately, decent tube amps are expensive! I highly doubt you are get anything approaching good quality on these designs. If your goal is to learn some electronics and soldering, then there is value here and a good place to start. If your goal is hi-fi music, I would look elsewhere and up your budget by at least 10x.
This is really the best bet:
http://www.tubes4hifi.com/bob.htm#ST70
You may find what you want here:
http://www.firstwatt.com/prod.html
This would likley be a good place to start
https://bottlehead.com/product-category/kits/loudspeaker-amplifier-kits/
You may find it useful to poke around here
https://www.amb.org/audio/
https://diyaudiostore.com/
https://diyaudioprojects.com/
ski2xblack
ski2xblack
@john11, what you propose can be done, with possibly quite good results, but it's way, way down the rabbit hole. To do it right, you essentially have to engineer an active speaker, which is not a trivial task by any means.
Years ago I tried it, using a pair of old LaScalas, a pro audio eq/crossover, ss amps for the bass bins, and four flea watt SET amps for the mids and tweets. The loads, high sensitivity and limited bandwidth of the horn loaded drivers sidestepped the inherent limitations of the amps, and while I could be completely wrong, it seemed like the SET's inherent lack of crossover distortion paid dividends with the extremely low power levels and highly revealing horns involved. Fully active, eq'd, and time aligned 'Scalas sound pretty darn good.
It was a fun learning experience, but ultimately an over-complexified PITA time waster, more about techno tinkering than actually enjoying the music. I would advise you to reconsider your plans.
