Trying to find a home for my loudspeakers
James Leiren
I have a pair of ADS L730 loudspeakers that I purchased in 1981. I don't use them any more and need to get rid of them. I'm not sure but I believe these are very high quality loudspeakers, still in excellent condition. Looking to see if anyone knows more about these or may be interested in purchasing them.
tcarcio
Looks like they are going for between $250-$400 a pair depending on condition. A quick search got this info.
Specifications L730
Frequency Response: 30 - 23,000 Hz, ±3 dB
Impedance: 6 Ω (nominal); 4 Ω (minimum)
Efficiency: 92 dB SPL with 2,8 V RMS (1 watt) pink noise input measured at 1 m in typical listening room (2000 ft³)
Driver Complement:
One acoustic suspension soft-dome tweeter, ¾" diameter, with single-layer, high-temperature metal voice coil; magnetic flux density - 1,8 Teslas (18,000 Gauss); magnetic flux - 325,000 nanoWebers.
One acoustic suspension soft-dome midrange driver, 1½" diameter, with single-layer, high-temperature metal voice coil; magnetic flux density - 1,5 Teslas (15,000 Gauss); magnetic flux - 1,000,000 nanWebers.
One long-excursion, high-compliance woofers, 10" diameter, with 1½" high-temperature voice coils and tapered Stifflite cone; magnetic flux density - 0,9 Teslas (9,000 Gauss); magnetic flux - 850,00 nanoWebers.
Crossover: 12 dB/oct at 550 Hz and 4,000 Hz
Power Rating: 100 Watts (nominal), 175 Watts (max. Peak program)
Recommended Amplifier Power: 20 Watts minimum - 200 Watts maximum
Dimensions (H x W x D): 25½" x 14⅛" x 11¾"
Weight: Approx. 42 lbs (19 kg)
Cabinet: Select natural walnut over extra-high-density particle board, solid oak or walnut edge inserts.
Baffle: Piano black finish with diffraction-corrected flush driver mounting.
Grill: Acoustically transparent removable frameless grill in complementary finish.
