Whole house speakers
Do you have impedence matching volume controls? If so, check the jumpers on each control to see if they are set appropriately for the total number of speaker you have connected to the receiver (5 pairs). If you don't have this type of volume control, get them.
The impedence matching allows your receiver to run safetly with 5 pairs of speakers connected. It devides the total power of your receiver (<100 watts / channel) by the number of speakers (4 or 8 jumper setting). Assuming your receiver has 100 watts and the control are set to 8, each speaker maxes out at 12.5 Watts.
Your best bet is probably an amp for the whole house system. Check out the Behrenger A500 ($200) or the Audiosource amps ($1-200). These will give you the power you need to run that many speakers.
