I've never heard of running each coil off a separate channel, only running them in series or parallel. I have to imagine that running the coils on separate channels could introduce issues where the signal is slightly different.
You get the same power running the amp at 4ohm bridged as you do running each channel at 2ohm, since each channel is seeing the same load, but you have the added benefit of the channels being sync'd.
