First of all I am so glad I found this forum. I don't want to waste your time so here is my Set Up:
Toshiba HD-A20 DVD Player
Onkyo TX-SR800 Receiver
The LCD is only used for picture. The speakers are all Bose in a 5.1 set up. Important to note that image is coming to LCD via 25 foot HDMI cable out of DVD player and sound is coming into the receiver from an optical out.
There are times, inevitabily when I have guests, that I put in a DVD, for example in this case Transformers HD DVD, and I get no sound. My receiver simply reads Analog input, and no sound is coming through. Here is what I have tried to fix it:
Set the DVD player to Bitsteam (which it is usually on and works fine)
Made sure the settings on the receiver are on Optical 1 and digital selection is on AUTO (my only options are analog/auto/or DTS)
Upgraded all firmware on DVD player
What is strange is that I can take out the DVD and put another DVD in on occasion and it will play the digital sound. Also, it will play the digital track from the DVD on occasion and not play on occasion.
Could I have a bad optical cable coming out of the DVD player?
Is there another setting I should be looking for?
Thank you so much for your help.
LeeOrtz
