Tripp Lite $98 with LCD readout
selkec
selkec
I have my tv and receiver plugged into it. Its nice to keep watching tv with surround while the power is out while my neighbors are getting out there candles. :p
N
nhpm510
Posed this question in Dec 06-priced about the same-no replies
I think I saw it for about the same price then--still looking for more wisdow. Also, would it be okay to plug my other AH recommended tripp lite (under $5k system-Tripp Lite HT10DBS )- strip into this? Or is that overkill?
Tripp Lite's OMNI900LCD vs APC H10 Audioholics Recommended
Is there any difference in "voltage regulation" btw these two? Seems like the bottom one is just oriented at the computer market and will cost less than half of the Home Theater version of a similar product.
Signed,
Audio on a Budget
APC H10 Power Conditioner/Voltage Regulator
Price: $299 ($279 street price) [Find Lowest Price Online]
Sure, you can just get a surge protector for $10 and pray it works. On the other hand, with a few thousand dollars invested in home theater equipment you might want to be a tad more cautious. APC's H10 series gives you an unprecedented value in a unit that features noise filtering, surge protection, and automatic voltage regulation (yes, I did say voltage regulation) for under $300. It's also UL approved, unlike many (dare I say most) other power conditioning products, including those that costs about as much as a large LCD television and promise to make your colors more vivid, increase the size of your soundstage, and make standard definition television look like high-def. We use these (and the more robust S-series) in our reference systems - need we say more?
Tripp Lite's OMNI900LCD Line-Interactive Digital UPS System offers voltage regulation, surge suppression and long lasting battery support for personal computers, home entertainment systems and media centers. Internal UPS circuits support entry level PCs for up to 50 minutes or individual VCR/DVR components for as long as 2.5 hours during power failures. Prevents data loss, viewing interruptions, lost recordings and loss of component programming. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 89 volts back to usable levels without using battery power. Offers complete power protection in an attractive black tower configuration. Includes 4 battery-supported and surge-protected outlets, plus 4 additional surge suppression-only outlets for items not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure, USB cable included. PowerAlert software available via free download from www.tripplite.com. HID compliant USB interface enables full integration with built-in power management and auto shutdown features of Windows, Mac OS X and Linux. Built-in audible alarm and large LCD front panel voltage display indicates line power status, battery power status, battery low/replace status and voltage boost operation. 900VA / 475 watt power handling ability supports entry-level PCs, home entertainment systems, network workstations, audio/video components. Offers 5 minutes battery runtime with a full load of 900VA/475 watts and 17 minutes with a half load of 450VA/237 watts.
audiofox
These have been $99 at Costco for the past year or two (I have three), and the local one (Torrance, CA) still has a large stock if anyone in SoCal needs them.
L
Livin
I have the CostCo one also... 1000 VA (OMNI1000)
It is so-so if you are used to a server level UPS. It does not last very long when the power is out and I do not have a powerful PC.
... in all not a bad deal, just not great.
