tri-channel home theater speakers?
MACCA350
MACCA350
What happens if you buy a projector with a huge screen, you cant really move the speakers further apart to suite :rolleyes:
cheers :)
soundsfine
I guess that was my concern. Since the "mains" are set pretty close together I wondered whether they would image well at all.
Boston has one like that also. I think it's kind of a dumb gimmick.
jcPanny
jcPanny
Tri-channel
These system look like they are designed primarily for esthetics.
The close proximity of main and center channels is equivelent to setting all 3 speakers right next to each other. The small drivers in this type of speaker also limits and performance and frequency response of the speakers.
If asthetics are a major concern, look into onwall or inwall speakers for your HT. They can be painted to match the room making less obtrusive than bookshelf speakers and brackets.
Another option for a single speaker enclosure below the screen is the Yamaha sound projector. Multiple drivers in different directions will simulate the surround sound effect in a square room. See the Audioholics review for more info.
They don't work for me aesthetically. In fact, I find it less attractive to have one big array.
