AVRat said:
The 901s w/active EQ can’t be used with most current receivers alone. The new receivers don’t have the tape monitor loop feature like vintage receivers. Nor do most have pre/main-ins to use the pre-outs. In most cases, you need a separate amp to make proper use of your 901s.
Agreed
I have never owned a pair . But freinds i know did and still do , there a pretty fine speaker and need more than what a Yammy reciever can give them to sound good . I agree with AVIrat , that you need a separate power amp to make them sing , preferably 150 w RMS and over . The more power the better for these babies .
If your gonna go Multizone with these , i would scrub the Multi zone and just get a used pre/ pro and a CD player and set it up in your room and have 2 separate systems ( 1 for HT and 1 for music , hell i have 2 pre's with multi zone and i dont use the multi zone feature in both and run 3 separate systems in my house) .
Those 901's are very good speakers and worth building a 2nd 2 channel system around .
