The Hsu VTF3 is a terrific sub, but it is very large. It will have output much greater than the SVS or Aperion subs. The Hsu might be a PIA for your landlord if you like high volumes, but you can always turn it down. On that note, any powerful sub is going to be a nuisance to your landlord, or, to be more precise, any loud bass. The Hsu might be overkill, but so could the SVS or Aperion subs, depending on how the house handles the acoustics of bass. In this respect, the key difference between the Hsu and the SVS or Aperion is you can always turn the Hsu down if it is too much for you, but you can't really turn the SVS or Aperion up if they are too little for you.
