Yes, you would use the Toslink (or coax) digital connection for audio and component cables for video.
By the way, Toslink is the name of the fragile little plastic connector on optical cables. Coax digital cables are terminated with RCA connectors. Both pass signals in S/PDIF format. Use either - they are the same in terms of audio quality.
