Just ordered the pioneers early this morning only to finally get a reply email from pioneer stating that my receiver has too much power for the sp-fs52's. I will be smart about setting the crossovers and balancing, so hopefully it will work out and I'll let you guys know.
I mean when I am watching movies right now the loudest I turn up the volume is 55 and that's with the Polk TL2 satellites. The power output rating on the Onkyo is 170 W/Ch (6 Ohms, 1 kHz, 0.9% THD, 1 Channel Driven, FTC) meaning that the power rating is given for one channel powered at a time over a 1kHz frequency so the total output at 6ohms should not be anywhere close to 170 in the real world (am I understanding that correctly?). Also, the sensitivity is only 87 db (pretty low) with the sp-fs52 so the general consensus is I should still be ok, yes?
