As mentioned it is distortion that blows speakers not power. I have surrounds that are rated at 100w and I run them with a Crown amp that puts out 300w per channel and they have been together and very happy for over a year.
Use common sense and don't overdrive them. Have fun and CRANK IT UP...
Wrong, wrong, wrong, and, oh, wrong.
Please do a search as there are multiple posts on this subject. I have responded to many of them. There is also a very nice article that was done on the site, I believe it was 3-4 parts long.
Too much power over time will cause voice coil failure. (heat induced failure)
Too much power can cause mechanical failure.
When an amplifier clips fully it will double it's output power from the rating at around.1% thd. A 100 watt amplifier fully clipped will output nearly 200 watts.
When an amplifier fully clips, it also outputs additional harmonics besides the fundamental. Combined with the increased output power from clipping it can cause over excursion.
Too little power cannot blow speakers as they would blow every time one turned down the volume control.
Manufacturer power ratings can be inflated or far from accurate depending upon who determined the rating (engineering vs. marketing).
