AudioArcher said:
My Pre-amp has two phono inputs and my turntable cartridge is a MM. I f I buy a phono pre-amp and use one of my tape inputs will I get an improved sound from my turntable. By the way my turntable is a Rega P3 and the pre-amp is David Hafler DH-101.
Is there anything wrong with your turntable sound now, or do you just have the upgrade bug? You can always try an outboard phono preamp, but I wouldn't buy one unless it included a 30-day money-back trial period. Of the few outboard phono preamps I've heard, they can be prone to picking up noise and interference, i.e. loud humming. You may have to move it around to different locations, away from other gear, to minimize the interference. The preamp section in your Hafler is likely to be better shielded and probably works as well anything you can buy for a reasonable price.
If money is really burning a hole in your pocket, you are more likely to hear a difference in sound by changing the cartridge than by using a different phono preamp. I'm going to guess here that you already have a good cartridge.
