Exactly. Seems like the best bet, and simplest, will be to just hook up one driver per channel.
Thanks highfigh, lot's of good tips in there.
DRIVER SPECS (10" High-power polycone woofer)
Nom imped 8ohms
Pow hand 160wrms
Freq rang 29hz-2500hz
Sens 91dB 1watt 1meter
Voice coil res 6.9ohms (Re)
Mech Q fact 7.632 (Qms)
Elec Q fact 0.364 (Qes)
Tot Q fact 0.347 (Qts)
Eq vol 98Lt (Vas)
Cone area 0.0346 (sq m)
most of the above detail mean nothing to me
AMP SPECS (
link) - VERY SIMILAR TO, NOT THE SAME, mine is just an older model I believe
Power / channel @ 4ohm 14.4V: 130WRMS x 4
Power / channel @ 2ohm 14.4V: 190WRMS x 4
Power / bridged @ 4ohm 14.4V: 380WRMS x 2
Signal/Noise ratio: >90dB
Input sensitivity: 200mV to 5V
Low pass filter: 50 - 500Hz @ 12dB/octave
High pass filter: 50 - 500Hz @ 12dB/octave
Pass thru RCA: Yes
Dimensions: 400(L) x 258(W) x 50mm(D)
I hope that helps.
