If you run your wires properly, dressing them up higher by using cable hooks and or Zip ties you will be fine, of course, if you see lots of Rat Crap then you may want to use conduit. Every attic is different, analyze the environment. You can also use a heavier jacketed plenum or Direct Burial with gel speaker cable meant for if your really particular or don't want to deal with conduit.
