Tips for Canadian Newbie?
L
Lithp
ok
I've just about finished my basement and want to set up a home theatre with surround sound quality. I have at best, $2500 CDN to spend. A Best Buy just opened up in my city (Red Deer, Alberta).
Can anyone suggest a home theatre set up for a medium sized rectangular room 13' by 28'?
Essentially I need the following:
-receiver
-speakers: (can I get Axioms in this budget?) Should I go for 5.1, 6.1 or 7.1???
- I have a so so DVD player (which I would also use to play CD's) but if you have any reccomendations I am listening...
I will most likely be buying a LCD projection TV and have a sattelite connection. This is separate from my HT budget.
Any help would be appreciated.
Should I buy separate components or a pacakage. As I understand it separate is the way to go but more expensive...
Thx
Rip Van Woofer
Rip Van Woofer
Geez, there are gobs of good receivers and DVD players at nearly all price points. Just remember, the speakers and room are what make or break any system sound-wise so put the most of your sound budget there. Besides Axiom also look at Paradigm and PSB (both fine Canadian makes) for speakers.
Not into HT myself so I'll leave the video suggestions to others.
However, a 28' long room (about 9 meters?) ain't too shabby! Were you talking about a rear-projection LCD? If I had that much projection space for an HT I'd be looking at if I could swing a front-projection system -- if not now, then maybe in the future. Maybe a used projector would fit the budget? Also, I understand that while there are very expensive screens out there, one needn't go top dollar for a good one. And again, maybe there's a second-hand market. What do you video mavens think?
If you meant a front projector, ignore that whole last paragraph! ;)
