Time for new center channel
L
landonspop
Budget 500-1000
I have a 12 year old Paradigm center channel model CC100.
My fronts are Eosone 1000's
Rears Definitive Tech's
Sub Defin Tech supercube 1
I know it would make sense to go with Def Tech again, but I know I do not want to change out my Eosone 1000's. I also have Eosone 600's for future side (7.1) speakers. So I think the center should match my Eosones.
Definitive Technology - Mythos has aluminum dome tweeter
When matching speakers, is the tweeter match the most important?
Eosones have 8 OHM 3/4" TITANIUM DOME TWEETERS.
AVR is a Denon 3808.
bandphan
bandphan
i would prefer the same lcr, but since your keeping the mains, how is the tweeter seated?
Budget 500-1000
Seriously consider this.
http://www.madisound.com/catalog/index.php?cPath=35_40_402_275
bandphan
bandphan
I am not sure what seated means.
how its placed in the design of the speaker? find out who the oem was, and the crossover settings in yours, then timbre would be a little better.
edit> after searching, the rsc300 center channel from eosone has been sold a couple of time on ebay which would match. Along with that i have find a large amount of drivers for the (eosone)speakers for sale, were they issues with blowing drivers at one point?
Build my own?
Not sure I went to page you intended. Click on link yourself and lt me know if you see what you wanted me to see.
Thanks
It is the correct link. Putting it together is very straightforward.
