Firstly, thanks for the meaty reply OttoMatic.
Sure, man, my pleasure.
Probably not. After all, once I've sorted out the room's acoustic problem areas, I could just use Yamaha's numerous music/movie DSP effects to shape the sound to my liking.
OK, one preset is cool. The reason I brought it up was because many people will boost bass for movies (they sound kinda flat and boring when using a truly flat frequency response). But most music people want a flat response for music (myself included).
Good point.
I have to admit that it's the PEQ part that I see being of greatest use to me. Unless I'm forgetting why a crossover part would be advantageous too...
Yeah, you probably won't need a crossover. A BFD will be fine.
Gotcha, but if I use a PEQ in the way I described above, wouldn't I have the advantage of being able to EQ not only the sub, but the portion of sound coming out of the Fronts and, should I choose, the Centre, given that I have pre-amp inputs for these channels on the Z9?
I had a quick look at your receiver. What you need to be able to do what you're describing is a "tape loop." I didn't see it called out in the specs, but it may be described somewhere in the manual.
You're talking about going into the receiver digitally (e.g., from a CD player), going out the analog preamp outputs, into the EQ, and then out of the EQ and back in the preamp inputs on the Z9. The problem is that you'd have to select the preamp inputs as the input to be used. Once you do that, you've no longer selected the CD as the input, and you'll have no sound.
If you have a tape loop, you can do it. Otherwise, you can't.
Other options -- use the CD player's analog outputs to feed the EQ and then go out of the EQ into any analog input on your Z9. That will definitely work, but will have the following drawbacks:
- can't EQ other audio sources, only the CD player
- can't EQ digital sources for movies, etc.
So, all that said, I'll also throw in this -- most people using EQ target it for sub-duty only, for these reasons:
- difficult to measure room response as frequency increases. Once you get >200 or >500 Hz or so, the response gets really ragged. This is because there's just so much audio bouncing around the room that it becomes a mangled signal.
- If the measured signal is ragged, then you can't create filters to "fix" the response
- an added A/D/A stage
- any other noise introduced to the "main" signal from the Behringer equipment. These devices have been cited to introduce "grain" and other noise into the system. Of course, that noise is much less audible in the sub range, and many people are happy to use this stuff for sub duty.
You noted that you're using room treatments already. I'm curious as to your current complaints about your sound. What don't you like? Also, can you post a frequency response plot?
Now, I'm not trying to tell you
not to EQ your mains if you want to, and I'll be happy to keep chatting about general setup and measurements and such. Just noting that most people don't do it because of the downfalls.
I already have
ETF for measuring my room's response to 1Hz accuracy so I'm sorted in this respect.
That's looks like a cool tool! The reason I brought up REW, though, is that it's so well-integrated with the BFD. It'll measure, calculate filters and then upload those filters to the BFD -- all in about 10 seconds. If you're a tweaker and measuring and setting filters in a loop, it's quite handy. OTOH, if you're happy with what you have, stick with it! You'll just have to enter the filters to the BFD by hand (as well as do the calculations for f, BW and gain).
Why do you want to keep the BFD at a predetermined level? Surely you want the volume feeding into the BFD to change in line with the volume on the amp no?
Yeah, sorry, I think I wasn't clear about that. What normally happens is that we set the input to the BFD (by using the output levels of the preamp) such that they're at their highest level that you would ever listen, just prior to where the inputs of the BFD will clip.
To do this, I usually take a real bass heavy movie (yeah, I'm sub-focused on this, but the concept will apply if you want to EQ full range) and crank it up to as loud as I would ever possibly listen. I can then adjust the output of my preamp until the loudest parts are just bumping into the red of the measured input to the BFD. I now have the greatest amount of dynamic range and the highest SNR at the BFD input. Of course, that statement applies only at that loudest point, but it's the best we can do.
You're right -- as you control your volume knob, the input level to the BFD will indeed change; it has to. The thing I don't want to do is say -- this movie is too bassy, and turn down the sub output level of my preamp to knock off some of the bass. You want to do that
after the EQ's output. And that little RLC-1 allows me to do that.
If you've ever set up a device to record a live input, it's a very similar process. Think of setting up a tape recorder -- you have someone talk into the mic and you watch the meters. Then continue to adjust the input leve at the loudest level that's going to come into the mic. That way you're getting up to the higher end allowed by the recording device without clipping it. Then, when it's too loud at the speakers, you turn down the volume knob, and not the input level. Anyway, something like that.
All right! That's enough for now.
