Timbre matching new speakers
da5176
Hi, just got some Polk monitor 30 speakers and was wondering what center channel would be best timbre matched to these, Polk or otherwise?
mazersteven
mazersteven
The same speaker as the left and right mains.
so_cal_forever
The CS1 and the CSi3 are the center channels offered in that range of the polk line. mazersteven is trying to say you should try and match those 30's with a speaker of similar drivers for the best timbre match.
nova
nova
For the best timbre match, use another Polk Monitor 30 for your center channel. If you don't like the look/thought of another Monitor 30 then a Polk CS1 would likely be the closest timbre match.
