Tidal connect enabled Streamer Amplifier
real_shark
Dear Audioholics,
I have been in the look for a some time for a new setup that would allow me to stream music from Tidal decently and in an uncomplicated way to a couple of Wharfedale loudspeakers.
Eventually I decided that I wanted a streamer that supported Tidal connect, so I was looking into a streamer like the one from bluesound and a separate stereo amplifier.
However the number of Tidal connect supported devices recently exploded:
My preference would be to get an integrated Streamer Amplifier which can provide more than 100W per channel, is somehow a bit versatile (maybe with USB, digital and analog out, in case I want to use an external amplifier or DAC) and does not break the bank.
Has anyone already taken a look at this?
Thanks,
RS.
John Parks
John Parks
Well... From your link, it appears Onkyo and Denon do Tidal Connect, but I am unsure which models or even where to begin as they have not been in my wheelhouse for ages.
My next choice would be the Bluesound Powernode for $899 (yes, it is above your $800 mark and is only an 80wpc NAD amp): https://www.bluesound.com/products/powernode/
Possibly the Sonos amp? 125wpc at $649: https://www.sonos.com/en-us/shop/amp.html
I guess it depends on what platform you would like to invest in. I prefer Blue OS (running Roon). I do not have any experience with Sonos or Heos (Denon).
There are a lot of options out there for an all-in-one; unfortunately, it seems the prices just go up!
nbk13nw
nbk13nw
The Yamaha WCX-50 and an external amp works for me.
Sent from my SM-G988U using Tapatalk
Curious why you even want to support Tidal/MQA vs other services?
real_shark
Before Tidal published more and more Tidal Connect enabled devices the setup I liked the most was Bluesound node + XTZ edge a2-300. These are two devices and the cost would be sligtly under 1000€.
I am now trying to explore options in the new list. Like you, I really have little clue with Onkyo or others nowadays. How about Pioneer? The SX-N30AE seems to be a really good option for the cost, it is network enabled so it should support Tidal connect with a firmware update, but it seems to be out of stock everywhere.
If I am going to spend 1000€ I would probably go for the two element configuration with the Bluesound node + XTZ edge a2-300.
Edit: It seems like in the list of "compatible devices" from Tidal, when filtering by Tidal connect, you get a significant reduction in the number of devices. This takes away Denon, Onkyo and Pioneer out for instance.
I couldn't care less for MQA but Tidal is what I use for streaming and it works well with me and my family, especially with Tidal connect.
I checked these devices some time ago but they were not Tidal Connect enabled and they are still not in the list.
Thanks to all,
RS.
nbk13nw
nbk13nw
I use the Yamaha MusicCast app with Tidal.
real_shark
But I believe not with Tidal Connect. Or do you?
The thing is that I want to use the Tidal app a not a third party app for Tidal. Several providers have been linking to Tidal for a while but pushing the streams directly from the Tidal app is a much more enjoyable workflow for me, especially with multiple Tidal accounts home.
RS.
real_shark
After consideration I still believe that Bluesound node + XTZ edge a2-300 is the best option I have for that kind of money.
I am almost certainly going to go for that one.
RS.
Thanks to all,
RS.
Just curious, as supporting Tidal is supporting MQA (since no one else has adopted such a stupid codec). Spotify Connect I bet works even better....but might depend on what you're used to for library.
real_shark
I do not even have a Tidal HiFi subscription :)
I think Supporting Tidal is not the same as supporting MQA, especially Tidal connect.
I am happy with Tidal as an application and but have no requirement for proprietary losy encoding and fancy blue lights so I am not going to upgrade.
I just want to use the application we use home for music streaming in the best possible way and with what I consider quite a good quality.
I already bought the EDGE A2-300 POWER AMPLIFIER FROM XTZ and most likely I will buy the Bluesound node 3rd generation in a few weeks. If I later change to Spotify, which I think is unlikely, I will keep the same hardware.
I hope this will keep it decent and future proof.
RS.
