THX Surround EX mode
taxman1948
I just bought the Pioneer 03 and it works great.. I see what everyone was raving about..Everything works great, cd player, cd jukebox, cable box, PS3, I pod, USB drive.. All controlled flawlessly by Harmony 1000.. It also detected all my speakers in a 7.1 system with PCM showing on the display.. My question is how to get to THX surround EX? I press the THX button but only get: Movies Cinema and Games.. thanks in advance
bandphan
bandphan
Its encoded in the dd soundtracks and was implemented as the "6th" surround channel. Try one of the lucas star wars films. Your manual will state the THX processing:)
from pioneer
• THX Surround EX
THX Surround EX - Dolby Digital Surround EX is a joint development
of Dolby Laboratories and the THX Ltd. In a movie theater, film
soundtracks that have been encoded with Dolby Digital Surround EX
technology are able to reproduce an extra channel which has been
added during the mixing of the program. This channel, called
Surround Back, places sounds behind the listener in addition to the
currently available front left, front center, front right, surround right,
surround left and subwoofer channels. This additional channel
provides the opportunity for more detailed imaging behind the
listener and brings more depth, spacious ambience and sound
localization than ever before. Movies that were created using the
Dolby Digital Surround EX technology, when released into the home
consumer market may exhibit wording to that effect on the
packaging. A list of movies created using this technology can be
found on the Dolby web site at www.dolby.com.
Only amplifier and controller products bearing the THX Surround EX
logo, when in the THX Surround EX mode, faithfully reproduce this
new technology in the home.
This product may also engage the “THX Surround EX” mode during
the playback of 5.1 channel material that is not Dolby Digital
Surround EX encoded. In such case the information delivered to the
Surround Back channel will be program dependent and may or may
not be very pleasing depending on the particular soundtrack and the
tastes of the individual listener.
GlocksRock
GlocksRock
Not sure about the pioneer receivers, but with my old yamaha, to get THX Surround EX mode, you first had to engage the Dolby Digital EX decoder, then turn on THX.
You should be able to apply THX-EX to any DD or DTS stream. It is post processing.
taxman1948
Thx
thanks for the quick replies... I was viewing Hulk using PCM from PS3 to receiver.. I was only able to view the 3 above modes when pressing the THX button on remote.. I will try Phantom Menace later
er..
Lordoftherings
Lordoftherings
Important > Select all audio codecs from your PS3, that your VSX-03 can handle
Hi Taxman1948,
Your answer is in the post above yours, from j_garcia. You will be able to choose any THX audio modes (post-processing) from a Doby Digital or DTS audio stream soundtracks.
I believe that you cannot apply THX to multichannel Linear PCM audio modes.
Please, someone correct me if I'm wrong (I might just be).
* Put a DVD disc with a Dolby Digital or DTS soundtrack on your PS3 and choose THX Cinema audio mode.
** But, don't forget to select the digital Optical audio out to "Bitstream" in your PS3 audio setup menu.
Plus select the digital HDMI audio output to "Bitstream" in addition to all the other audio modes (codecs) that your Pioneer Elite VSX-03TXH can handle; again in your PS3 setup audio out menu.
*** And, in your receiver, select surround EX "activate" from the THX modes, with the two rear surrounds enable in THX mode. I believe that you can program your receiver to Automatically apply it (EX), or to Manually select it. Just check in your receiver's manual.
Bob
