After i installed Behringer PEQ I read that they recommend having it plugged into reviever/processor so that it powers on before the sub to avoid the loud thump. the plug on it has a ground prong so i cannot plug it into my reciever. I tried plugging it into the Pure AV power console switched outlet but it takes a few seconds to power on and I get the dreaded thump.
I then plugged into the always on outlet on the power console and the Behringer now stays on at all times with no thump from the sub.
Any fixes for hooking this up where the behringer can be powered off and on with the rest of the components without the thump?
I was wondering if i hooked it back up to the switched outlet and left the SVS on always on instead of auto if that would help? But I am assuming even if it is always on, as soon as the signal comes through the input the thump would arrive.
