Thoughts about the Definitive Technology DI 6.5R In-Wall Speaker?
HTKamikazee
Audioholics Sheriff
Even though there is a review on this speaker, I wanted to know your thoughts on this speaker. Has any of you experienced with at least a pair of these?
Here is the link to the review:
http://www.audioholics.com/outdoor-speaker-reviews/def-tech-di-6.5r-in-ceiling-speakers
FEATURES:
  • Flangeless design & micro-perf grille minimize visibility
  • Simple to install — no spackle work required
  • 8-5/16" (21.04 cm)total visible diameter is about the same size as competing 5-1/4" models
  • Perfect for use as side/rear surround speakers for Mythos and BiPolar-based home theater systems
  • Latest generation BDSS drivers for audiophile-grade sound quality
  • Pivoting Pure Aluminum dome tweeters
  • Axially Aligned design ensures broad, balanced coverage area
  • GaussGrip™ magnetic grille fasteners
  • Adjustable high-definition crossover
  • Optional fire-rated enclosures
  • Cast PolyStone™ baskets for rigidity without "ringing"
SPECIFICATIONS:
  • Tweeter Diameter: 1"
  • Tweeter Type: Pivoting Pure Aluminum Dome
  • Mid / Woofer Diameter: 6 1/2"
  • Mid / Woofer Type: BDSS Midrange Driver
  • Tweeter/Mid Array Type: Direct Radiating 2 Way Coaxial Control
  • Environmental EQ: 3 Way Switch
  • Speaker Level: 1 Pair (Heavy Duty Spring)
  • Maximum Sensitivity: 1 watt @ 1 Meter / 90 dB
  • Total Frequency Response: 26 Hz - 30 kHz
  • Nominal Impedance: 8 ohm
  • Power Handling: 10 - 200 watts per channel
  • Diameter: 7-1/4"
  • Mounting Depth: 3-5/8"
  • Grille Diameter: 8-5/16"
  • Weight (Out of Box): 3.8 lbs.
  • Carton Height: 6-1/8"
  • Carton Width: 10-1/16"
  • Carton Depth: 10-1/16"
  • Shipping Weight: 5 lbs.
  • Warranty (Drivers and Cabinet): Parts and Labor / 5 Years
PRICE: $279.00/each
zieglj01
zieglj01
Very nice, isn't it? Check out the following features and specifications and let us know what you think about this design!
Well, that is a lot of marketing hype on their part - a lot of things that
are suppose to make it sound good - so I guess that they do/will have
a voice coil inside, which would be one of the key parts.
All in all, all that hype is more of a distraction - yet they should sound
decent.
