thickest speaker wire that fits common speaker binding posts
mike c
mike c
:rolleyes: what's the thickest speaker wire that fits common speaker binding posts? (what gauge)
MDS
I would think 12 gauge is the thickest that would easily fit in standard binding posts and even that is overkill unless you have very long runs.
mike c
mike c
thanks MDS. was imagining at least an 8 ... thought it would have looked nice.
MDS
I don't know Mike. When I was much younger and not very knowledgeable about audio, I bought 10 gauge wire. That stuff is so thick and unwieldy it is almost impossible to work with (and of course for the lengths I was using it didn't make one bit of difference to the sound compared to 16 gauge wire).
mike c
mike c
I agree about the sound difference, only considering the "looks" part. but if you say 10 gauge is hard to work with ... I'll skip it.
I do have lots of 14 gauge lying around, and the longest run I have is 5-7 feet.
mike c
mike c
you're right, the 14 gauge I have could barely go through ... 10 gauge max maybe. oh well. I'll bi-wire instead :)
majorloser
majorloser
Moderator
Haven't you ever seen these cable companies with HUGE cable then they put pin connectors on the ends.
Heck Mike, run some number 4/0 wire with pin connectors ;)
audiofox
Now I know what to do with all the service entrance cable I have left over from my panel relo project. :p
If you just want looks, why not just get some tech flex? Large AWG wire really doesn't buy you anything in the typical system.
Haoleb
Haoleb
"Common" binding posts is a pretty open statement...
I have some that wont accept regular spades, some that wont take a bare wire larger then around 14-16 gauge, some that will take bare wire up to like 8-10 gauge. It really depends on the equipment.
mike c
mike c
will look for some fancy cables when I get to the US or Canada :)
btw, I leave on oct. 7 and will be back on nov. 15 or 16 I think.
you guys get that long a vacation from all my questions and polls :)
dont go celebrate all at once.
