gmichael said:
I like most of what it does for me. But I don't like how it rolls off the highs with the EQ settings. I run mine then go back in and set the EQ's to flat. This has been the best sound for my system. But you will have to make sure that you have good room accustics.
The rears almost always sound low because most movies do not have much coming from them. Tweeking them up a little shouldn't hurt as long as you don't go overboard. If you later find that in some movies the action overpowers the dialog, you may need to tweek them back down.
I agree! I got two words for people who feel they need to EQ their room: "
Just Say NO!" ;-)
Fix the acoustics instead. For starters, EQ doesn't properly fix modal issues in a room. You can reduce some of the peaks, but it won't fix modal ringing. Ethan Winer and Terry Montlick did some experiments with this.
http://www.realtraps.com/eq-traps.htm
You can see the difference between what EQ fixes and what acoustic treatment fixes in that article. I think there are some other articles around somewhere about that.
Plus, if you EQ for one listening position, it's only going to be good for that listening position. The person sitting next to you or behind you is going to hear something different than you hear. For that matter, if you move your head an inch or two, you will hear a different result if you pay attention to this. Proper acoustic treatment actually fixes the problem by attenuating the reflected sound just enough so that it doesn't interfere with the direct sound from the speakers. To EQ a room (especially if it isn't a very god sounding room) is to put band-aid on a broken arm.
Cheap EQ sucks, because it distorts the sound in all kinds of funky ways. There's a reason high end amps and preamps don't come with tone controls. Why would you want to put your sound through something that only screws up the sound. Even most cheap gear these days has a pretty flat frequency response. So if it doesn't sound right, the problem is most likely your room.
So maybe just use the YPAO as a starting point for levels, etc., but leave the EQ flat, and get some proper acoustic treatment if you still aren't happy with the sound. You'll hear detail, imaging and dialog a lot better too, including for your surrounds.
