The latest project, Micro Minis
billnchristy
I am building a set of PC speakers around 3" Tang Band full range and 5.25" tang band sub.
They are designed to look similar to the Strata Minis from AV123.
Here is a pic, note the grille is just taped together for show right now, the final product will be much cleaner, I just dont know the cutout size yet as the drivers havent come.
I
ilnoca
I'm looking at doing a very similar project with the 3" TB full ranges for my computer speakers. I haven't figured out what sub to use, but the TB 5.25 looks pretty good.
I assume you've finished these by now. How do they perform? Also, what amp did you use? The apex jr. is a little bigger than I want (I'm want the amp to be seperate from the sub), and the only other thing I've found that looks reasonable is the 30W Velleman kint from PE. Any advice is much appreciated.
Thanks,
Sam
