The inverse square law states that in the free field, each doubling of distance equates to a loss of 6dB. Rooms are not free field, and the sound that would typically be radiated into space is contained and reflected by the room boundaries.
To determine just how much spl drop applies in a real room, I measured the spl at 1m, 2m, and 4m. According to the inverse square law, I should have experienced a 12dB loss at 4m. At 1m, the spl was 71 dB using band limited pink noise from 500hz-2khz. At 2m, a drop of 3dB occurred, reading 68dB, at 4m, 63dB, or a loss of 5dB from 1m. Increasing the distance beyond 4m (which was about 13’) caused no further loss of spl, however, my room is only 20’ long, so a longer room with more space to the rear wall should continue seeing drops.
When deciding how much power/speaker we need, the peak spl calculator is often referenced, however, this calculator only adds an additional 3dB for room gain, but still follows the inverse square law for increasing distance, therefore, it would estimate that we need much more spl than necessary.
Take my situation for example. The in room sensitivity of my speakers up front is 96dB @1m. I sit 10.5’ away, according to the calculator, this means I lose about 10dB, meaning I’d need about 100w to achieve 105dB Reference level peaks. If we take the real world example I just tested, I actually only lose 5dB, dropping the required power to only about 25w.
My room is fairly well treated too, so others may experience even less of a dB drop. Based on the results of this, I think we should revise calculations for average in room drop.
Is anyone else here with an spl meter willing to test spl drop at 1m and then 2-4m and compare results to the expected 6-12dB loss? I’d be interested in see if this varies significantly by room or even room size.
