jc1carter829@ho
The amp is connected to the Yammy by the pre-out connection. The speakers are bi-wired to the Yammy and the Rotel Amp. What I am doing wrong? The tweets are connected to the Yammy and mid-range (bass) is connected to the Amp. Or should I not bother with the amp at all and just go with the Yammy for everything, but how do you connect the bi-wiring with the Yammy?? A + B speakers or what other channel can I use instead?? Still a newbie. Thanks for any help you can lend.
While I'm at, where can I buy speaker wire and what brand should I use for the Front speakers (bi-wiring) with banana ends???? THX YOU
