While you can measure voltage with the meter connected in parallel, you will need to connect it in series in order to measure current. In other words, disconnect one of the leads to your woofer and measure from the disconnected one to the connected one. If the woofer is in good shape, though, you don't need to measure current. If there is voltage across the leads, then there is current. Others have suggested tests to see if your woofer is OK or not. Good luck.
