I ran ethernet throught my new home and used the same ports as you. The ports come with a cheap tool that is probably usuable if you're only doing a couple. I had to terminate about 40, though. Luckily, my bro is in IT, and gave me a punch down tool, of the adjustable type. I used the low setting. It was very hard to punch down on the high setting. Also, it has a reversible tip. I didn't realize until I had done 2/3 of the ports that the end with the longer side that is pointed will also trim the excess wire after it is punched down. This yielded a much cleaner install. Prior to that I was using scissors, and still had ~2-3 mm of wire proutiding out the side. But as it is in the wall, no matter.
