Technical Help Denon S720W
Corey Gibson
Looking for some technical help if anyone can.
I have a Denon 720 receiver with a front left and right speaker as well as a center channel and sub.
Until today, the sub has been working fine. Today, the sub will not output sound when watching a movie, tv, or music. The power light on the sub is illuminated.
The "set up assistance" sends a musical chime to each speaker to verify connection. When doing this I can hear the chime through the sub.
No settings were ever changed so I'm wondering why it's only putting out sound during set up assistance mode?
What playback/sound modes are you using? If it can still get test tone signals its most likely a settings issue. If the settings haven't changed try a reset, either a simple one (unplugging it for a bit) or the microprocessor reset (should be explained in your manual).
