Technical Consultant for Landman
K
kdkoger
Just have a comment about the blowout in episode 2, the technical consultant needs to up his game a little. First, you should never beat on a steel pipe wrench with a steel hammer, sparks cause the explosion, an aluminum 24” with a 48” snipe would be a way better idea. The star of the show runs in to the well without any heat shield or breathing apparatus. Secondly he was yanking and pounding the pipe wrench in the wrong direction, in reality it would just pop off the valve, jaws need to bite to be of any use. Unfortunately it just looks very much like amateur hour and you guys need to correct this kind of thing, anode that works in the patch will pick up on these things right away. Good luck, looks like it might be a good series.
isolar8001
isolar8001
Hmmmm.....OK.
But, do you know where you are ? I'm your age and I do. :)
Anyhow, I watched half of the first episode of this new show and turned it off....pure garbage.
