TC Sounds Axix 12" Quad Voice-coil sub
JTF2
I need some amp suggestions for my sub, as well, how do you hook the quad voice-coil up?
the sub is 1000watts rms and 4000watts peak
Warpdrv
Warpdrv
http://www.amazon.com/TC-Sounds-Axis-12Q1-Subwoofer/dp/B0039OX4UW
I assume that is the sub you are running here...
Are you going for sealed or ported - or Passive Radiator...
PR would be a great use for this sub with 2 of TC Sounds 15" PR's found HERE
Ported or PR will get you the greatest amount of output.
I would shoot for the diagram on the top here to get you pretty close to a 4 ohm load, in which a Behringer EP2500 or EP4000 bridged would do a great job for that driver for pretty inexpensively.....
