I am using a Clark Tactile Transducer TST229 100 watts continuous and 350 peak @ 4 ohms.
I am trying to feed it an LFE signal from my Integra DTR 7.1 that is split at the amp (One to the sub (Klipch 15") the other goes to the transducer via an Adcom 555 (600wats Bridged).
I do have the Adcom bridged but do not set the sub output on the Integra to more than +1 sometimes less depending on the type of music and or soundtrack I am listening to.
If I use a stereo output it works fine but as soon as I try a theater setting Dolby/DTS it keeps blowing the internal fuses in the Adcom.
The instructions from Clark say use the front speaker pre out but as the transducer is rather slow and the rest of my system is faster it distorts the sound or I get an echo but no blown fuses.
I spoke to Adcom and Clark both said there should not be a problem using the LFE out to the transducer.
Any ideas?
