OK... this might wind up being a long one - and I'm sure you guys are sick of this type of post, but since we're all in to A/V technologies... it can't get too old can it?
If you don't care for the preface to this novel - skip down to the asterisks line...
My house is small and sucks for audio - well, pretty much for everything... ( But it's paid for so meh - no mortgage = I can live with it ). I've previously been dealing with TV in my family room which is the worst ever - 45" wall for TV
and speakers (yes 45
inches) with fireplace on one side and breakfast bar on other side - no side walls for 20' on either side of the TV, 16' vaulted ceiling angled down to 12' above seating area... which is only 10' from the TV! And the main traffic flow through the house is between the sectional and the entertainment center.
After getting 'clearance' from my wife - I'm planning on setting everything up in the living room/dining room and turning the family room into a dining room (hehe). Still have a valuted ceiling (now it will be 8' at TV and speakers rising to 16' at the back - which is the old dining room). So my media room will now look like this: 15' wide X 22' deep, left wall solid with 2 smaller windows, right wall extends from the front 8' and then opens to the entryway. Not perfect, but much better.
On to the real issue - I previously owned a Klipsch Synergy 5.1 system circa 1993 - which I hated. Everything sounded very congested to me with extremely directional highs which seemed bright yet rolled off (horns) and with the center channel actually sounding like it was swallowing the dialog rather than presenting it. Have upgraded receivers several times - not actually expecting different sound... it was for features (more digital inputs, HDMI switching, room EQ) - before just giving up on the project.
Currently the living room is home to my 2ch setup which is just a pair of Polk RTi A1's on shot-loaded stands and a small Infinity Sub (which sucks). 2ch components are: Cambridge Audio 640A integrated, 640C CD player, DAC Magic, and my custom built touchscreen jukebox which has all of my CD collection ripped to FLAC.
So I want to build one system for everything - I'll sell off / give away all of my current gear or use it in bedroom system(s). I really don't have a budget per se - however, I have some other financial goals - so lets say $5K as a ballpark.
What I mostly want is a system that is without compromise in the 2ch department as I listen to music 90% of the time, never watch TV, and only watch 1 or 2 movies a week (if I'm lucky). In addition to the Polk bookshelves and the Klipsch Synergy 5.1 system... I picked up some cheap Tekton Design speakers - with Fostex FE207E's as their only driver... and before you start... I love them! OK... yes they are missing, well almost
all of the upper range, and they have a hump in the 3Khz area (mostly fixed with a BSC)... but the resolution is unreal. They actually made me enjoy watching TV/Movies - although not enjoyable for music as much (other than female vocals which are heavenly).
So what I most want is that kind of point-source clarity and resolution, but with the bass and treble that I'm currently missing. I have a Pioneer VSX-1019AH-K currently doing nothing other than powering the Fostex boxes and switching HDMI for me. I like the feature set of that receiver, but some of the speakers I have auditioned, and many I've researched I think will be way too difficult load-wise for it's amp section...
My thoughts are:
1) Stay 2.1 CH: Maggies (1.7's - which I've heard and loved) running off a very high-current amp - possibly either one of the Wyred4Sound ICEPower amps or maybe dual Emotiva XPA-1's. Plus a good pre-amp & DAC (or at least a DAC with volume control and numerous selectable inputs).
2) Go 7.1/2 - Keep VSX-1019AH-K, have rear and side surrounds installed in ceiling, and purchase front towers + center that are an easier load (and what isn't compared to the Maggies) and subs. I've auditioned KEF iQ, Focal 700 & 800, DefTech Mythos, B&W CM series as well as ML Source, Polk RTi,LSi, Klipsch Reference. I liked the Focal's and the B&W's, thought the KEFs were 'decent' but I had to audition them at Fry's and the sound room was horrible to put it nicely. I didn't really like the DefTech's or the Klipsch's - for similar reasons that I don't like any of the other Polk RTi series other than my A1's. And the others would be too difficult for the Pioneer AVR to drive I think - Polk LSi and PSB Imagine in particular - although I liked the LSi's and I like the PSB's on paper at least - nowhere to hear them tho.
3) Similar speaker selections as above but possibly initially just going with a 3.1 setup in front so as to avoid the initial cost of having the ceiling installs done. Replace the VSX1019 with either a Marantz 8000 series (refurb/used) or a new 6000 series, or Emotiva UMC-1 + XPA-3 (with plans to later add in a UPA-5 for the surrounds in conjunction with ceiling install).
OK... my novel is finished... I'm not it a rush - although I am looking forward to really enjoying good sound as soon as possible. The biggest thing is that I want to spend this money once... at least for the next several years. And before you ask, I'm planning on spending at least as much as I spend on the front speakers in room treatments where possible & WAF-acceptable.
