bigdaddy0130
hello to everyone. i hope that i can get some good answers here. my system is as follows. denon 2106, sony 400+1 dvd player, sony bravia 46' hdtv, and a dish network hd tuner. my spkrs are polk rti38, polk csi40, surrounds are polk r15. my subs are ars112ps and a cheap rca pro sw100. to be honest the system does not sound bad, but need to be fine tuned.(1) if this was your system how would you set it up.(2) how would you hook up the subs. and (3) what would you set the xover at in the receiver(both subs xovers are turned all the way up) any and all help would be welcome:rolleyes:
avaserfi
avaserfi
(1) Well a diagram of your room would be helpful, but the general speaker layout can be found right here.
(2) Just run a splitter from your receivers subwoofer pre-out to both of your subs inputs. Placement with two subs is actually a rather hard thing to do, but if you do it well you will have great results as the second sub can help flatten your frequency response and give you more SPL. This will help you place your first subwoofer. Once you have done that, you will need to use your SPL meter, test tones and graph paper to set the second for a better frequency response. If you want to just increase loudness place the second sub on top of or as close as possible to the first.
(3) In general 80Hz is where you would want to set the crossover because that will help reduce the localizability of your sub. To do this I would recommend turning your subwoofers crossover all the way up and relying on your receivers crossover by setting it at 80Hz.
To best set up your speakers I would recommend going to Radioshack and buying a digital or analog SPL meter and then going into your receivers speaker level set and setting all the speakers to the same loudness as this will help keeping speakers from drowning each other out.
Also, a video/audio calibration disc would help as well. I personally use Avia to calibrate my display and it also has many great audio tests that will help you get your speakers set up properly.
bigdaddy0130
not that good of a drawer, but i got the size of the livingroom(12'-2'x13'-10) from my sweet spot to the right is open( i am in a apartment) have to get a spl meter soon, i used the auto setup in the denon avr. i did use a y to connect the two subs set the sub level in avr to 0db. and turned the volume on both subs to 10'o clock, like i said before the system is not bad but i know it needs to be fine tuned. maybe if i can save up some money i can buy 2 really good subs and replace my surrounds with the polk fxi30 or 50
