System Fidelity SF-4050 Speakers - Advice Needed !
Mijoci
Hello to all, I'm playing to buy a pair of speakers and i want your advice.
The speakers are System Fidelity SF - 4050. http://www.avstore.ro/en/speakers/system-fidelity-sf-4050-/
Everyone have heard/listen this speakers?
The brand (System Fidelity) is new from what i've heard and their claim to offer good quality per price compared to others competitors.
At begining, i like the Jamo S718.
Initially (without offer) Jamo S718 price was 485 USD and SF 4050 price was: 606 USD (i made the conversions because in my country USD isn't oficial). I found an offer at SF 4050 with 409 USD.
Differences :
Jamo S718 have a 10 inch woofer compared to SF 4050 wich has a 8 inch woofer.
Jamo S718 have 2 speakers for mid's compared to SF 4050 wich has one.
Jamo S718 sensibiliy is 92 db compared to SF 4050 : 90 db. From what i've heard less eficienty means better response in audible frequency (20Hz-20 000Hz) but also need a powerfull amp.
I have a room wich has 3.5 meteres x 5 meters.
I liste pop, rock, electronica, jazz and rarelly hip-hop.
The amp is Harman Kardon Hk 980.
The differences really matters in sound quality in this price range and in my room?
In the end, should i accept this offer and buy Sf 4050 without hearing it? I'm thinking that with 409 USD i have no chance to buy something better and i'm afraid that this offer disappear quickly.
My personal opinions are:
SF 4050 has a woofer with 2 inch less than Jamo S718 and have 1 speaker for mid compared to Jamo = > less speakers and small woofer at more costs => more quality i think.
Initialy SF 4050 cost more than Jamo S718 - i think they are better.
Personally i like the SF 4050 look more.
Thx for reading. I can hardly wait your opinions.
BoredSysAdmin
BoredSysAdmin
Tech specs alone wouldn't tell you if the speaker will sound good in your room or not, unfortunately there is only one way to find out :D
Avstore.ro policies Do offer returns within 10 days from receiving the product so if you don't like it - you can return it :D
HK 980 is very capable amp and wouldn't have issue with neither your choices.
You also might want to checkout Infinity Primus 362 towers as very capable, yet inexpensive option. (AVstore carry P360, which I guess very close to 362 ones)
For Electronica, Rock, HipHop you might want to consider adding subwoofer to get better low-end response and lift that task from your main speakers.
kevo82
kevo82
Hi. After all, you bought the speakers? I bought a Panny 3D from them and now I will buy the AV receiver (Pioneer 9020). They recommended the same speakers, or ARGENTUM 07.1.
I never listen any of them. I am also looking for Dynavoice 5.0 System
Please tell me which one you bought, and which one would you recommend. Thanks
