Buckeyefan 1 said:
In the US, the Denon is the AVR 3805. The site for your speakers is very limited. I didn't see any specs on those speakers.
Hmm...not sure if I read you correctly there. _Some_ specs are there. E.g. for the fronts (SA1550) they are:
SA1550:
power handling: 175 Watts
impedance: 4 Ohms
frequency response (+/- 3 dB): 40 - 35.000 Hz
sensitivity (1W, 1m): 90 dB
crossover (24 dB/oct.): 700 / 3000 Hz
dimensions (W x H x D) cm: 13 x 105 x 27,7
Other details: 4 woofers, 1 tweeter; Option for bi-amping/bi-wiring; rubber base; 2 1/2 way system, etc, etc.
Or you actually meant more detailed specs ?
Buckeyefan 1 said:
I'm not knocking those speakers, but they may be rating them at 4ohm to hide the fact they can't handle the power at 8 ohm, and may be so inneficient to protect the fact they are small. I'd say great Denon amp, but find some 8 ohm speakers.
The reason I got the "courage" for asking the question in the first place is that the review for the [D or A, pick ur poison]VR 3805 here at audioholics used 4 ohm speakers (RBH Sound 1266-LSE) that were pushed to 97 dBs "without a sweat" (to literally quote from the review).
Moreover, since it seems to be possible do bi-amping with the 3805 (from the same review) and the speakers I am considering do support that option it should mean that (theoretically) they could be "pushed" more even if they're just 4 ohms (Side note: The fact of how "smart" --or not-- is doing bi-amping with the 3805 and/or doing it w/ those speakers notwithstanding)
Anyway, as always, the proof of the pudding is in the eating. I'll try to get the receiver anyway and do a test w/ those speakers.
Lastly, thanks for pointing out the Bic speakers. They sure look nice. Judging only from the specs they should deliver quite a bass but the highs look a tad low (21/22 kHz... distortions/softness ?). However it may be, after a very quick search (admitedly) I cannot find them anywhere near me and I have to more or less choose smth "closer". But thanks anyways for the tip.
