SVS Ultra Tower package... What receiver should I get?
Z
zackmac_3
Hey guys, i'm just ordering the SVS ultra tower package and have never really had a decent home theater setup before. I'm looking for some suggestions on a receiver that will be ideal for these speakers? I will probably be getting an SVS sub in the near future as well... Price range is anything under $1500, I was looking at the Denon AVR-X4000 but don't really understand all of the amp output/THD stuff yet. Any help would be greatly appreciated!!
How big is your room and how far away do you sit? They are 8 Ohms and 88dB sensitive, so I probably wouldn't go too slim on the power. The X-4000 and the Marantz should both be adequate, but it depends on the answers to those questions and how loud you expect to listen.
Z
zackmac_3
Thanks for the response... I don't need a ton of features, looking at the Marantz now it seems to have everything that I would use. The main question is the power, I would like to be able to blast these things and not worry about the receiver not having the power to supply. The room I am in is about 30 feet by 15 feet, straight rectangle. And do you think dual subs is going to make a difference worth that much extra money in this size space?
