What do yall think of having the Ultra Bookshelf on its side, instead of it being up right?
Toy Audioholic Intern Dec 22, 2023 #1 What do yall think of having the Ultra Bookshelf on its side, instead of it being up right?
S shadyJ Speaker of the House Staff member Dec 22, 2023 #2 Toy said: What do yall think of having the Ultra Bookshelf on its side, instead of it being up right? Click to expand... If you do that, you will really want to listen on-axis so make sure you have that tweeter aimed at you. The problem is that a speaker like that usually has an even response at a horizontal angle but a very uneven on the vertical angle. This isn't normally an issue because most people listen at roughly the same height although over a wide horizontal angle. By setting the speaker on its side, you are making the optimal horizontal listening angle into a very narrow one. So you won't be able to listen outside of a small area before audible problems set in.
