SVS subs keep resetting to 90 degree phase.
K
KurantAK
Is there a reason they would do this? Isn’t 0 the factory default? Or is there any particular reason they would always set to 90?
Is there other gear that may be adjusting phase upstream of the sub?
Mark E. Long
Mark E. Long
Do you have anything locked in in the presets to make it do so when it powers up .
Mark E. Long
Mark E. Long
Maybe the app is overriding the default of 0
I believe if you have presets locked (or Stored ) in your presets yes I believe it will go to that if set to auto on . Or you could try setting them back to factory default and start over .
