SVS Prime Ultra Bookshelves and Center for LCR and went with the SVS SB Pro 1000 since my room is relatively small - 11x10. I'm pleasantly surprised by how everything sounds given the limited placement options, but I'm wondering if I might be better off going with the 2000 Pro to avoid overdriving them?
In a room that small, sitting as close as you do, there is no need for a SB2000.
Going with a ported sub is a different story. It might be indicated, if you felt the really low end of explosions and such in action films/games was lacking.
By "them" at the end of your paragraph I assume you mean the Ultra bookshelves.
You will not overdrive the Ultra's due to any of the subs you cite. A 80 Hz or higher crossover selection should protect them just fine.
- If you play exceedingly loud for extended periods (and like going deaf) then you are much more likely to fry a tweeter, which the sub has nothing to do with.
Cheers,
XEagleDriver
Sent from my SM-G975U using Tapatalk
