SVS PB12 Plus VS 2 PB NSD
steelworker
Hello how is everyone doing.
I am wondering what you gentlemen would think or recommend in a my situation.
I recently bought a PB NSD and I am very happy with it 95% of the time, it digs Low and it's very accurate. I find myself wanting more of the low stuff and I'm wondering what I should do?
I've read good and bad things about using two subs so I'm. Wondering if I should just sell the NSD and get the PB PLUS.
In all fairness my basement is large about 17*25 so it is a large room to fill.
So what should I do? Please help
Nathan
N
NewHTbuyer
From what I understand, adding a second sub gives you more output and smoothes the response around the room, but doesn't really play lower. So, probably getting a plus is the way to go.
Definitely call SVS to see what they say. Usually their advice is pretty good.
One more thing, is your setup right now optimized? Do you have room EQ? Is the sub optimally placed? Maybe refining your current setup would give you the results you want for free. Often the room dictates much of the sound, so changing subs might not do that much.
steelworker
Thanks for the advice,
I find the sub digs low enough but it just doesn't have the power to pressurise my basement.
I don't plan on upgrading my sub or subs for the next few years so I want to get it right.
Hope that helps
