SVS PB12-Plus/2 Sub
Cavediver
Is there a better sub than the SVS PB12-Plus/2 for the money? The SVS is $1,199 on the SVS website.
Sheep
Sheep
Its been argued that, No, there isn't. I would say no, judging by its numbers. But, I would advise looking around, and waiting for more replies.
The only thing that can best that for the money(IMO) is a DIY sub, which involves work.
SheepStar
Buckeyefan 1
Buckeyefan 1
Sure, any other SVS sub. ;)
That's a mighty sub for a small room. It all depends on the size of your room, listening tastes, etc... The PB12/2 is an awesome sub for $300 less, and the single Plus sub is a great sub for a smaller room. But for $1200, IMO, you can't do better unless you build one yourself - especially for home theater usage.
Cavediver
"Look at the HSU VTF3 HO/Turbo sub."
I just did and it doesn't appear to be available in the US. Additionally, it appears to cost a whole lot more.
"That's a mighty sub for a small room."
The room is not small. It is a long narrow open room which encompases the living room, dining room & kitchen, (13' W X 47' L X 8.5' H). It is approximately 5200 cu. ft. total. SVS recommended the PB12 ISD/2 as a minimum, but indicated that the PB12-Plus/2 would be better and the Ultra 2 would be ideal.
BMO
The VTF 3HO with Turbo should be about $1000. The just started shipping some out last week.From the initial reports over at the Hsu forums, it looks very good indeed. Many are waiting for more reviews on the " Ho" before making there next sub purchase.
DOJ
I have been extremely happy with my SVS PB12+2 . For the money it seems it is hard to beat for HT and total output .
For music you may want to look at the UFW-12 as well . Incredible sounding sub .
I'm using both in my system with great results . :)
