Fast question is the upgrade from a 2000 pro worth it to go 3000 and why.
Searched the web found no answers let's fix that.
Well it really depends. Why are you interested in an upgrade in the first place? Deeper extension? More output?
Do you have a PB2K pro already? How many? How big is the room? Movies or music?
Short version to your question would be...
The 3000 series is very special. But at 60% more a pair of pb2000 pros would be a better solution, and cost a little more than a single pb3000 after multiple sub discount. You would gain headroom, but more importantly if you have room to place them correctly, better FR potential. This can many times be more important.
Not really that simple lol. Room size is also a huge part of the equation.
Singe pb3k to single pb2k pro? The 3k IS better, but it’s MUCH more expensive so....
it depends!
