SVS pb-12/2 box vrs. 16-46 PC-Plus cylinder
jpaul
jpaul
I'm looking at buying the SVS sub. Which of these would be the better choice? the SVS pb-12/2 box or the 16-46 PC-Plus cylinder?
I like the down firing of these speakers.
Thanks
JPaul
scotty11
i have the pb12/isd2 and it is a massive house shaking beast.
you cant hide it but if you want "wow" factor for home theater then the choice is easy.
with the 2 you wont have to think about upgrading.ever.
ive heard the 16-46 and it is a great sub.it has a much smaller footpint.
if your ok with the size of the box then i would choose it over the 16-46.
scott
jpaul
jpaul
Thanks, I've made my choice it's the PB-12 box.
Jpaul
scotty11
you wont be dissapointed.
they are great subs for the money and IMO nothing compares in the same price range.
Sheep
Sheep
Woa Woa WOA.
What PB-12 is it? Plus? ISD? Ultra?
The PC-plus will have much better fidelity compared to the ISD/2.
The PB-12 with have more output, but more THD compared to the Plus.
SheepStar
