Suubwoofer recommendations - purely music
Josh784
I'm looking for a new subwoofer to replace my current Velodyne VX-10. When I built my stereo I skimped on the sub so I could spend money elsewhere, but no longer do I plan to deal with an inferior subwoofer.
I have a pair of Axiom M2i speakrs, Yamaha HTR-5550 receiver, and Pioneer SACD player (not elite). Price range is around $400.
So far my best bet seems to be HSU's STF-2, but I am very open to other recommendations, as the STF-2 seems like it may be geared more toward home theater, and I only plan on using this subwoofer to listen to music.
Thanks,
Josh
Yamahaluver
Yamahaluver
If it is music you want, check out offerings from REL and Yamaha, notably the Yamaha YST-SW800 or the YST-SW1500.
Josh784
Thanks for the reply, but...
neither of your recommendations fit into my price range, unfortunately :(
cbraver
What do birds have to do with subwoofers? What a waste of bandwidth.
But I second zumbos recommendation. NHT has some affordable stuff worth a listen! That link he posted is a good deal.
-Chad
Mr.T
Chad, you're absolutely wright, I thought I was inserting some colors into our black & white conversations, I didn't think about taking space away from the forums.
Redbone
You must look at Adire Audio RAVA sub my good friend-
Francious70
Francious70
I'll second that. Adire Audio makes some AWESOME subs. Check out the Brahma 15" too.
Paul
jotham
Subwoofer recommendation
This sub may not be quite as musical as some I've heard but it's also substantially less expensive. Being a sealed design, it doesn't have some of the one note issues that you might worry about. It has so much possible output that you will have to turn down the sensitivity to avoid overwhelming your speakers. Piece of cake to assemble.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-760
10" TITANIC MKIII SUBWOOFER KIT
K
kingtut
I vote for the Hsu. It's known to be musical. I have the VTF3 MK II and very happy w/it for both music and HT. It's little brother, STF2, should be very close in performance.
